Dynamic Blocks Forum
How to insert parameters of a dynamic block into VBA
1 REPLY 1
Demasure1
1950 Views, 1 Reply
I have made lots of dynamic blocks with parameters, like length, width and height.. i trying to make a cabinet with a lot of dynamic blocks.
my Question is: ---> How can i get my parameters in vba?
I want to change the block with a vba.code.
I am new with vba and i don't know how i can get my variables or parameters ( don't know the differents) in vba..
So i am looking for a code.
I have made a code to insert the block into autocad.
Sorry if my english is bad.
I hope somebody can help me.
1 REPLY 1
kasperwuyts
in reply to: Demasure1
Dynamic blocks have a property in VBA called GetDynamicBlockProperties, which returns an array of the parameters of the block. You have to type in this property yourself completely, but you will see VBA recognises it when it adds the caps.
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-16C8768B-2533-45FF-9CFF-FF864AC78202
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
”Boost
”Tips
”Services
