Dynamic Blocks Forum
How move flip parameter with dimensional constraints??
5 REPLIES 5
627 Views, 5 Replies
Hello.
Can not move the plip parameter "ejevertical" to get the of the door leaf when change the size of its width.
How can I do if I do not use linear parameters?
I've tried to move with a move action, a factor 0.50, associated with a new linear parameter of the total width, but I know it work.
Can anyone help?
Mateo.
5 REPLIES 5
Caduser_zero
hi mateo,
what version of cad are you using because I did not see any dynamic properties in your block.
in reply to: Caduser_zero
Hello Caduser_zero:
I work wit Autocad 2011, but I saved the file in Autocad 2007 format. There can be the problem for look dynamic properties.
I attached new file.
Thank you.
Tags (2)
Caduser_zero
Hi Mateo,
looked at the block in 2007 and 2010 format and neither one shows any dynamic properties.
The dwg file include a dynamic block named CANCELADIN1A.
I have a  poor solution with a Visibility Parameter for a single door.
AcadAdamLT
One way to solve it Smiley Happy
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
”Tips
”Services
