Dynamic Blocks Forum
How change Dynamic Block Size
3 REPLIES 3
352 Views, 3 Replies
Hi
I have problem w/change size of dynamic block.
The block name is 'a' and that is simple rectangle w/action stretch and value name Distance - how change this value ?
That is my code:
var MS: OLEVariant;
Block := MS.InsertBlock(0,0,'a',1,1,1,0);
Blok1.Value.Distance := 200; <--- !!! This is only my idea (off course doesn't work)
Please help my w/that problem
Regards
3 REPLIES 3
What format of code is this? VBA, .NET. DESIEL, etc?
Hi I use Delphi (object Pascal) or C++
Well, I have no experience with C++. The only suggestion I can make, is that the input value might need to be formatted in Decimal units, i.e. 200.0 This is what LSP required and may hold true for yours as well.
”Boost
”Tips
”Services
