Hey guys,
I would like to create an "Y" dynamic block, see bellow.
The hole lenght and the "cross" point will be variable, between the two sticks will be 90 deg, and it will be FIX.
I would like if I change the "variable 2" distance the two sticks follow the cross point, and the top of the sticks stay in the same level, but between the sticks the 90 deg stay!
Is possible somhow?
Please help me if you can!
Thx T
Solved by steven-g. Go to Solution.
I hope this is what you're lookin for. If not, I hope it's close. Let me know. And good luck.
Thanks a lot your quick answer!
It is close! 🙂
If I change the "variable 2" distance, the two sticks follow the cross point, but the end of the sticks as well.
They need to stay on the same level.
Could you offer solution in this case?
thx
saved down to 2010
Thank You guys!
It's working perfecttly.
Now I have to give it "body" with wipeout (see below).
What do you thing is it working whit wipeout as well?
@Anonymous wrote:Hey guys,
Is possible somhow?
Thx T
Please mark as solution solved.
I'm gald we were able to help you out.
Thank you one more time for your help guys!
It is working perfectly! 🙂
Is there any chance to make a list from the blocks?
And does it contain the dynamic blocks length?
I made a list for the "variable 1" and "variable 2" distance, and now I need a list /table /summary
where these size are shown.
Please help me again if you can!
THX
T
