hiy'all
I have a situation where I've a dynamic block of a type of part, whose part number would change depending on it's visibility state. I can quite easily set up a lookup property for it's part-number, but I'd much rather use attributes, as they'd then appear in the same column as simpler and legacy parts when I use EATTEXT for building a BOM.
I've tried setting multiple attributes of the same name yet controlled by the visibility but they all still appear in EATTEXT, is there any way to hide an attribute in a dynamic block?
Cheers
G
ACad, MEP, Revit, 3DS Max
