Why is there no dynamic block for the Imperial Hex Nut in the tool palettes?
Can I copy the Metric and convert it to become Imperial?
Where do I change Metric to Imperial in this dynamic block?
The simplest would be to scale (25.4 or .0254) the block first and then use a real world measurement to stretch and change the geometry of the block to match the standard size nut that you need.
Make sure you look at the Selection Set boxes for each Parameter affected by the scaling to see that they still encompass the areas they are intended to.
If a Block Properties Table is being employed change the values as needed for each given Parameter.
If the Parameters are set to List then change these values as needed. The list can be added and deleted to.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
