I have created a template that uses the functions of the title block updating tool. The team runs into an issue when the text is too large, it overruns the block the text is in. Is there any way around this?
Hi
First of, there is no way to have Autocad adjust the block or any entity in it depending on amount of characters in a text.
There are however usually some workarounds to the problem, post your block and let's see what we can do with it.
You can change the justification of the text from left or center to fit. It will stretch out short text to fill the space and scrunch up long text. It works OK if there is not too much difference in text lengths.
Well thats ok I was just wondering if this was possible, a more experienced coworker had mentioned it was but I didn't think so.
Thanks!
