Dynamic Blocks Forum
Help with Blockproperty tablet
0 REPLIES 0
Message 1 of 1
AcadAdamLT
176 Views, 0 Replies
Hello!
Havn't been spending so much time infront of Autocad past few weeks as I would have liked to but now find myself again infront of this wonderful program and my CAD-mind is slowly returning but in the mean time I'am in need of help...
What I want to do is to use the blockproperty tablet ( if possible ) to manipulate the attributes so that if the value of Attribute: "REF.BET" is set to "=H9" then all the attributes within the blockproperty tablet should be equal to "xxxxx", but if I change the Attribute: "REF.BET" to anything else I want all the attributes within the blockproperty tablet to be equal to " " ( empty ).
This is so it will be easy to edit each attribute by clicking them, and if I don't need any specific attribute it will turn blanck once I change the "REB.BET" to something else.
Thanks in advance!
/Adam
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
0 REPLIES 0
”Boost
”Tips
”Services
