Dynamic Blocks
Distinguished Contributor
jarredmonday
Message 1 of 8 (273 Views)
Help with arraying dnamic block
273 Views, 7 Replies
12-14-2012 05:55 AM
 I'm using a 2-2D recangles that are 5'x16" and 10'x16" and I am trying to figure out how to array this in one direction, to the left, but have the array on 5' increments. Also, within each rectangle I am needing text to show which size it is.
e.g. If I drag the array to the left more than 10' but less than 15' it will apply 15'.
Thank you.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
So there should be a series of 10' pieces with only one 5' piece on the end?
Charles_Shade
Message 2 of 8 (265 Views)
Re: Help with arraying dnamic block
12-14-2012 07:56 AM in reply to: jarredmonday
Please post your starting Dynamic Block and not just the rectangles.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
jarredmonday
Message 3 of 8 (261 Views)
12-14-2012 09:09 AM in reply to: jarredmonday
Okay, attached is the best I could come up with, but it is not doing everything I am wanting. The 5' peice should not always be visible the 10' peice should be visible at all times.
The 5' peice should only appear on 10' increments starting at 15'.   e.g. 15,25,35,45,55...etc and not appear on 10' increments starting at  10'.   e.g. 10,20,30,40,50...etc.
Charles_Shade
Message 4 of 8 (259 Views)
12-14-2012 09:14 AM in reply to: jarredmonday
jarredmonday
Message 5 of 8 (254 Views)
12-14-2012 09:49 AM in reply to: jarredmonday
Yes. I like your description better. Thanks.
Charles_Shade
Message 6 of 8 (250 Views)
12-14-2012 10:07 AM in reply to: jarredmonday
And the Dyn Blk?
Does it do what you need?
jarredmonday
Message 7 of 8 (247 Views)
12-14-2012 10:29 AM in reply to: Charles_Shade
The Dynamic block works great. Thanks a lot. I did, however add to it. I added a visibility set to show and hide the 5' section. Which just fine. See attached.
Charles_Shade
Message 8 of 8 (244 Views)
12-14-2012 10:32 AM in reply to: jarredmonday
Excellent
