Hi
I have just started using dynamic blocks and parametric constrainst and have discovered that when you add a constraint to a dynamic block, you lose all your newly created grips within your dynamic block :-(. A message box appears to inform you of this.
HOWEVER, I have managed to do it purely by accidient (ie, I've 2 dynamic visibility blocks which are contrained together and both grips work). THis is exactly what I need, but I cannot replicate it. Is this a bug or does anyone know how to replicate it again.
I've attached the block for anyone to have a look at. (Block one is the large shape and block 2 is the little triangle inside). I kinda think that if it works, then why do Autodesk have this limitation.
Any help would be greafully appreciated.
Welcome to the Autodesk Forums!
Why do you need the constraints?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
