Dynamic Blocks Forum
geometry won't change when using PROPERTIES dialogue box
4 REPLIES 4
809 Views, 4 Replies
Attached is a block of a side view of a mortise and tenon.  It has two dimensions, length and depth, which adjust nicely with the little blue grippy arrows (don't know what those are called).  However, when changing the dimensions in the PROPERTIES dialogue box only the Length dimension changes.  If I try to change the depth using PROPERTIES nothing happens. Why?  I would to input values in the PROPERTIES dialogue  box.
I'm new to blocks so I can't figure out why one works and one does not.
Thanks.
4 REPLIES 4
Libbya
You have the startpoint of the Depth parameter at the grip that you want to move.  Changes in the properties keep the Startpoint constant and change the length of the parameter by stretching the end point.  To fix it, rotate your parameter 180 degrees, delete the current stretch and add another one that is associated with the end point instead of the start point.  It can be visually helpful to set the grip display to 1 if you are only using 1 grip.  That way if the grip you want to use disappears, you know that you have your parameter backwards.  It also helps with block editing in more complex blocks.
I attached your file in an unfixed state (learning happens best from doing), but with an additional stretch action added to the other end of that parameter so the grip shows up and you can see what is happening when you change the properties.
in reply to: Libbya
Helpful. Thank you.
in reply to: Libbya
How do I change the grip display?
Libbya
You can select the parameter and either use the right-click menu or properties for the parameter.
”Boost
”Tips
”Services
