Thanks for the reply. As for the copy/paste function, yes, I've learned that
lesson the hard way before. I recreated this block from scratch, with the
same end result. Battman didn't help either.
Right now the block has 3 visual states. the first does not hav an
attribute. The second has 1 attribute. The third has 6 attributes and
doesn't include the attribute on the second visibility state. State 2 works
fine. The third state has the Attribute prompt that should not be visible is
showing for the wrong attribute tag. wierd. If i were to change the
attributes through vb or throught the properties dialog box they are all
fine. So my problem is having a block with multiple attributes on multiple
vis states.
