Dynamic Blocks Forum
FIT justification for Attributes
1 REPLY 1
mdhutchinson
416 Views, 1 Reply
I been doing AutoCAD Blocks since AutoCAD version 9
Now in 2013... Sometimes FIT option works for me...
... most times it does not.
Has anyone had any trouble with this - and or - found a work-a-round preceedure?
One point though: The block is Annotative = Yes...
If I set this to NO, in the block where it isn't working then it works as it should. However, strange as it seems... both the versions are Annotative...
1 REPLY 1
AcadAdamLT
in reply to: mdhutchinson
I havn't had any problems yet with the "Fit" option in 2013 yet.
Does the block have any dynamic properties that could give the fit attribute any problems?
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
”Tips
”Services
