Dynamic Blocks Forum
Filtering Blocks
4 REPLIES 4
Pointdump
666 Views, 4 Replies
Filtering Blocks
I've usually got hundreds of layers in my Civil 3D drawings, even though I might only use 20 or 30. All those unneccessary layers are not a problem because Re-Naming or Deleting Layers is easy, and with Layer Filters I can just show the ones I use:
With Blocks it's different:
It's impossible to get rid of unneeded Blocks (I've tried). It also doesn't seem possible to Re-Name them (to put them at the top of the list), and I don't know any way to Filter or Sort them. Any clever functionality out there I'm missing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
4 REPLIES 4
ojuris
in reply to: Pointdump
Are You try rename command to rename blocks?
Juris
Pointdump
in reply to: ojuris
Juris,
How do you access the Re-Name command? The only thing I see is a "Save As" command which does not delete the original. So then you have yet another Block in the list:
Dave
Dave Stoll
Las Vegas, Nevada
ojuris
Sipmly type command when you are in drawing, not in block editor
there you can rename many objects
Pointdump
in reply to: ojuris
Juris,
Thank you. I didn't know about the RENAME command.
Dave
Dave Stoll
Las Vegas, Nevada
”Boost
”Tips
”Services
