I've usually got hundreds of layers in my Civil 3D drawings, even though I might only use 20 or 30. All those unneccessary layers are not a problem because Re-Naming or Deleting Layers is easy, and with Layer Filters I can just show the ones I use:
With Blocks it's different:
It's impossible to get rid of unneeded Blocks (I've tried). It also doesn't seem possible to Re-Name them (to put them at the top of the list), and I don't know any way to Filter or Sort them. Any clever functionality out there I'm missing?
Dave
Dave Stoll
Las Vegas, Nevada
Solved by ojuris. Go to Solution.
Juris,
How do you access the Re-Name command? The only thing I see is a "Save As" command which does not delete the original. So then you have yet another Block in the list:
Dave
Dave Stoll
Las Vegas, Nevada
Juris,
Thank you. I didn't know about the RENAME command.
Dave
Dave Stoll
Las Vegas, Nevada
