Good afternoon,
I am trying to accomplish basically exactly what the title of this post says. I would like to have a callout that contains an attribute be able to look at our title block and return only the largest revision #. In other words I want for it to fill in with the most current revision #. I'm not sure if this is possible or if I'd need some type of LISP or something else?
Example #1: I would want the callout to fill in with "3".
REV # DATE
1 8/31/14
2 9/2/14
3 9/9/14
Example #2: I would want the callout to fill in with "2".
REV # DATE
1 1/1/13
2 2/5/14
Thanks in advance.
I don't know a way to do that. You could perhaps use a diesel expression for a formula field and get it to do that based on custom sheet set properties, but IF you use a field in that manner, each of the fields will automatically update when an additional date is added. I suspect that you do not want all of the prior revision callouts to update to the new number when an additional revision is added.
