We are seeing some problems with dynamic blocks and getting the error !scandr.cpp@1526: eWwasOpenForWrite error has anyone come across this before? What is it related to?
We are running 64 Bit, Windows 7 Operating System with AutoCAD 2011 installed.
The error occurs not when editing the block in the block editor but when you close the editor out and then try to adjust the block or try to get the grips to work.
Duncan
As a test have you tried RECOVER or AUDIT on the Container File for the DynBlk that is causing problems or is this widespread?
If it is widespread; has there been a Registry Cleaner run on the computer recently?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Yes I had this problem. However, it happens most of the time when I am mixing parametric constraints and parameters/actions within the same block.
I did not make a big case of this error since that just re-inserting the block (without any purge) resolves my problem and also that this happent to me less that 10 times.
I know this is not a solution to the problem, but I believe that it is the fastest way to go around it.
