Show only
Search instead for
I’m trying to create a dynamic block that has an attribute that users the Visibility state as its value. I’m having problems doing this. I can create a dynamic block and then create an attribute that looks up the blocks visibility state. But this means that I cannot insert the block. What do I need to do to get this to work? I’m not very familiar with Dynamic Blocks so can someone please give me a step by step example of that to do. Thanks.
I'm not 100% sure I understand your problem but if you want an attribute to show the same name as the vis state then just create on attribute for each vis state and use that vis states name as the default.
edit the attribute, and highlight the field text. you can 'edit field' w/ a right click to see what i did. I think all i did was change how you linked to the vis parameter. (sorry, yesterday was a loooooong day) 😉
OK, it almost works, I can get it to do what you have done. I then wblock it. Then insert it into the drawing that links up with the database. But instead of the visibility state it uses the default value you first put in, "Visibility". I think when creating the Attribute you cannot edit it after the block definitions have been created. When I'm in Block editor I, select the attribute and add a field. In the Objects Category there is a Field name "BlockPlaceholder" In this there is a Visibility reference. I cannot get this to work but it sounds like the right place to look. Is there any other way of getting the attribute to look up the visibility state of the block. The attribute needs to be included in the block.
I had the same issue until I inserted more than one instance of the block.
Then it worked ok. Why? I dunno. (AutoCAD 2006 SP1) The attached sample
works even after I deleted the first instance of the block.
R. Robert Bell
wrote in message news:5200665@discussion.autodesk.com...
I just tried testing. It works, but when I try to Insert it into the program, CADWorx, it does not work. The dynamic block still works, just the attribute is the default value, not the visibility state.
Well I was taken off the Dynamic block project. But now I'm back on it.
Below is the block I have created.
When I wblock it, then insert it into a new drawing it does not work (even if I insert it more than once), the old problem of the default value for the type still comes up.
R. Robert Bell's on off dynamic block works, so I know it is possible, so how do i do it?
If someone gets it to work please attach the wblocked file and tell what you had to do to get it to work.
I tried attaching a file, but it does not want to attach at the moment. Too Slow??? It seemed you already had the solution.
I first defined a block with an attribute. Inserted a copy. THEN, I opened that same block within the Block Editor and modifed the attribute to have a default value. I assigned a field from "Objects" > "BlockPlaceholder" > "VisiblityState". I saved and exited the editor. THEN, I synched up the attribute with "battman".
I had an example, but it will not attach at the moment. The text will not update if you change state. You must do a regen to update the field.
