Dynamic Blocks Forum
Dynamic elbow problem
6 REPLIES 6
laelic
243 Views, 6 Replies
Hi, i am going crazy with this one.
I trying to strech the diameter of my elbow, but the insulation line (in blue) and the center line (in red)
don't follow when i use the distance 1 parameter. Can someone help me out with that ??
6 REPLIES 6
coryv
in reply to: laelic
I no its a lil messy but hopefully will do the trick
laelic
in reply to: laelic
Dosen't do the trick. One of the blue line is scale more than 3in. And the pipe line dosen't follow the angle. Any other suggestion ?
coryv
in reply to: laelic
If you changes the width before the overall size it works. I know its a pain lol. Forgot to turn a couple grips to sorry
hinndnaser
in reply to: laelic
FROM BLOCK EDITOR YOU CAN USE OFFSET TO WHAT EVER WHAT YOU WANT.
Hugh_Compton
in reply to: laelic
You could always use the blocks from here:
http://www.3dcadmax.com/2DPipeFittingsAutoCAD.htm
hansoliv
in reply to: laelic
Hi!
I've already created an dynamic elbow, it shows 90º and 45º from 3/8" to 30" in top and left views (front still needs some tuneup).
Have a peek inside the block and see if it helps.
”Boost
”Tips
”Services
