Dynamic Blocks Forum
Dynamic elbow problem
6 REPLIES 6
248 Views, 6 Replies
Hi, i am going crazy with this one.
I trying to strech the diameter of my elbow, but the insulation line (in blue) and the center line (in red)
don't follow when i use the distance 1 parameter. Can someone help me out with that ??
6 REPLIES 6
coryv
I no its a lil messy but hopefully will do the trick
Dosen't do the trick. One of the blue line is scale more than 3in. And the pipe line dosen't follow the angle. Any other suggestion ?
coryv
If you changes the width before the overall size it works. I know its a pain lol. Forgot to turn a couple grips to sorry
hinndnaser
FROM BLOCK EDITOR YOU CAN USE OFFSET TO WHAT EVER WHAT YOU WANT.
Hugh_Compton
You could always use the blocks from here:
http://www.3dcadmax.com/2DPipeFittingsAutoCAD.htm
hansoliv
Hi!
I've already created an dynamic elbow, it shows 90º and 45º from 3/8" to 30" in top and left views (front still needs some tuneup).
Have a peek inside the block and see if it helps.
”Boost
”Tips
”Services
