I've only just discovered dynamic blocks. They are the business. I have a question about them though. When I import one into a drawing, can it be set up to automatically go to the first grip, then the second and so on.
Alan.
Many things can be possible in dynamic blocks but I do not understand your goal.
Can you describe more specific or with an examle dwg.
Take care....
Cycling thru Grips is possible but not automatic. Althought there may be a Lisp way of doing so.
In the attached DynBlk there are several Point Parameters that are there only to allow me to choose the best node to use.
Insert the Block and use Ctrl key to move it to the other points prior to picking the insertion point.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
