Hi all,
I've attached a drawing containing 2 types of blocks, a level marker with an attribute so when it's placed you enter the level, and some excavation cross sections, with lots of adjustable levels. If you look at these in the block editor they're fairly messy!
Right, I've got a few fairly simple questions...
Is there an easy way to turn the dimensions on the cross section blocks into metres? i.e. 500mm would become 0.50m... I've tried changing the drawing units, but that didn't seem to help.
Is there a way to have 2 seperate visibilty groups in a block, I want each cross section block to have the 3 stages, I would also like to have the 3 different scales in that block...without having 9 different visibilty states! I'm not sure if this is possible...it's not too big a concern having them in 3 seperate blocks.
I'm not sure if anyone out there is familier with AutoCAD Mechanical, but one of my colleagues is using that, and I tried to use the blocks on his pc and changing between the stages produced an error and shut it down. All the other dynamic blocks I made worked on Mechanical...is there something in these blocks that disagrees with it?!
One final question, I originally tried making the level markers in one block with 3 visibility states, using just the one 'level' attribute and scaling it differently in each state...however each time I would only be able to see the attribute in one state...the other states would just be different sized triangles!
Thanks in advance for any advice, I've spent a while fixing and fiddling with these, though I'm sure there are still errors...
Regards
Andy
