Dynamic Blocks
Active Member
Beaso
Message 1 of 6 (484 Views)
Dynamic Block
484 Views, 5 Replies
01-30-2013 12:51 PM
Hi there!
I am using Lt 2013, and would like to make a particular dynamic block.
The block consists of two lines, Line 1 and Line 2. Line 2 is half the length of Line 1. When inserted, the idea is that the length of both lines be reduced or increased by clicking and dragging the top end of line 1. Line 2 should remain half the length of line 1. The bottom ends of both lines should remain where they are, and the distance between the two lines should remain the same.
Can you advise if this is possible?
Thanks for your help.
Okay; but only because my arm hurts from the twisting.
Caveat: You only get three questions.
(And so you know: Your favorite color is blue.)
KateMorrical
Message 2 of 6 (477 Views)
Re: Dynamic Block
01-30-2013 01:20 PM in reply to: Beaso
You bet. Here's a hint -- look into stretch actions with distance multipliers.
Kate Morrical
Digital Design Manager
Washington, DC
BIMmuse.com
Charles_Shade
Message 3 of 6 (474 Views)
Re: Dynamic Block
01-30-2013 01:26 PM in reply to: KateMorrical
And Stretch Actions using only one Parameter.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Active Member
Beaso
Message 4 of 6 (452 Views)
Re: Dynamic Block
01-30-2013 03:26 PM in reply to: Charles_Shade
Sorry, but I still can't see how this can be done. I want to be able to stretch line 1 to a new length, and have the length of line 2 automatically adjusted to remain half the length of line 1.
Charles_Shade
Message 5 of 6 (445 Views)
Re: Dynamic Block
01-30-2013 05:17 PM in reply to: Beaso
Charles_Shade
Message 6 of 6 (441 Views)
Re: Dynamic Block
01-30-2013 05:32 PM in reply to: KateMorrical
BTW - We are going to fish before this is done.
Post #5 should be the Dynamic Block FAQ:
http://forums.autodesk.com/t5/Dynamic-Blocks/create-a-sticky-topic-or-a-wiki/m-p/2318033/thread-id/8...
