I am tying to create a Dynamic Block of a steel angle of multiple sizes and thickness. I used Dynamic Blocks before and live the idea of changing sizes on the fly with out having to delete and recreate an object.. I got as far as creating an angle of different sizes, i.e.. 4x4, 5x5, etc. and different thickness but can't get the thickness to work with the radius of the angle. Can someone out there walk me thru it. I have attached file
Solved by falconbird. Go to Solution.
Unless you are looking for a pure exercise in creating Dyn Blk's just use the attached or Google what you need.
There are multiple examples and Steel shaped blocks available.
Otherwise let us know and we can get you there...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I been looking for hell to high waters and or try to create a DB of angles and was going to try to do one in tubs. Where the hell did you get this??? O! by the way, thank you.
P.S.If there is a specific site/link please send it to me, thank you again.
Participating in this Forum over the last 3 years I've cobbled together this group.
Most of these are here in the Forum somewhere and one or two are mine.
Some examples of Stretching a Radius attached
And my good old contribution - not sure if I created this or just picked it off the discussion group or a combination of both. It has been a while since I rolled this out. Either way, many of the fine people here contributed to the creation of this via example, directly or just educating me on how to do it. Hopefully this will be a benefit to others seeking an AISC steel angle dynamic block..
Ron
