Show only
Search instead for
Please is there a way to load dynamic block parameters from an external file (ex. csv, mdb or others) and to automatically regenerate that block according to the new parameters?? is there a ready-for-use LISP script? or any API to download?
DBlock properties are available via ActiveX. There are several examples
posted in the Customization group.
R. Robert Bell
wrote in message news:5183363@discussion.autodesk.com...
ok thanks a million... i've already had a brief look at it but i didn't find anything suitable .. please can anyone help me found a specific case regarding dynamic block parameter writing via DB? thanks a million
Private Sub ScanBlks()
Dim dybprop As Variant, i As Integer
Dim bobj As AcadEntity
For Each bobj In ThisDrawing.ModelSpace
If bobj.ObjectName = "AcDbBlockReference" Then
If bobj.IsDynamicBlock Then
If bobj.EffectiveName = "cirtagleader" Then
dybprop = bobj.GetDynamicBlockProperties
For i = LBound(dybprop) To UBound(dybprop)
If dybprop(i).PropertyName = "Visibility" Then
dybprop(i).Value = "Leader Off"
End If
Next i
End If
End If
End If
Next
End Sub
The above example changes the "Visibility" visibility state of a block "cirtagleader" to "Leader Off" for each insert in the
drawing.
I'd like to know if there is a way to use wildcard in your code? I tried to replace the " If bobj.EffectiveName = "cirtagleader" Then " with " If bobj.EffectiveName = "SYM-M*" Then " so that all my blocks starting with SYM-M in my drawings are modified.
It doesn't seem to work Randy. Instead, someone on the VBA forums posted this code that works great:
Replace:
'If bobj.EffectiveName = "cirtagleader" Then
