Dynamic Blocks Forum
Dynamic block with stretch and Array
7 REPLIES 7
Message 1 of 8
Nicolethedrafter
1953 Views, 7 Replies
Hello
Is there a way to create a dynamicly stretch a block and an array creates a new set of diagonal once it reaches a given length?
7 REPLIES 7
Message 2 of 8
ojuris
in reply to: Nicolethedrafter
something like this
Message 3 of 8
Nicolethedrafter
in reply to: ojuris
Thats exactly it Smiley Happy
I am trying to break it apart and I can see the three diffect visibility states and stretch comands, but I am trouble with how you are relating the lookup paramater to the distance paramater.
Message 4 of 8
Here is what I am working with so far.
Message 5 of 8
ojuris
try this
Message 6 of 8
Agri-Design
in reply to: ojuris
ojuris that's a handy thing to do! But I cant see how you created this either. Any further info on this process would be good.
Regards
Message 7 of 8
ojuris
in reply to: Agri-Design
I use visibility parameter and double lookup
in 1st lookup table I use intervals for linear parameter, when block must change from simple bracing to double an triple bracing
in 2nd lookup I put appropriate visibility states for linear parameter intervals
Message 8 of 8
Agri-Design
in reply to: ojuris
For anyone else if you set the BACTIONBARMODE = 0 you can see how the above block from ojuris works.
see post here for info on double-dynamic-lookups
regards
”Boost
”Tips
”Services
