Hello
Is there a way to create a dynamicly stretch a block and an array creates a new set of diagonal once it reaches a given length?
Solved by ojuris. Go to Solution.
Thats exactly it
I am trying to break it apart and I can see the three diffect visibility states and stretch comands, but I am trouble with how you are relating the lookup paramater to the distance paramater.
I use visibility parameter and double lookup
in 1st lookup table I use intervals for linear parameter, when block must change from simple bracing to double an triple bracing
in 2nd lookup I put appropriate visibility states for linear parameter intervals
For anyone else if you set the BACTIONBARMODE = 0 you can see how the above block from ojuris works.
see post here for info on double-dynamic-lookups
regards
