Dynamic Blocks
Dynamic Blocks
0 Kudos
Post 1 of 6
Accepted Solution
Dynamic block - stretching equally in same direction
1080 Views, 5 Replies
01-05-2012 08:50 AM
I can create a block where you stretch a line and the opposite side stretches equally in an opposite direction but I can't find anything to help with stetching equally in the same direction.
The block in questions is a door with windows to the side. The door size will remain fixed but as I stetch the window jamb I would like the two mullions to stretch to create an equal stretch.
I've had a look for a how-to but can't find anything similar. Can anyone help?
This?
You can change the scale of stretching.
This can be done in the proporty window of the action
(it is called distance multiplyer)
If you set this parameter to 1/3 it wil normaly work just fine
Thomas
*Expert Elite*
370 Kudos
Post 2 of 6
Re: Dynamic block - stretching equally in same direction
01-05-2012 09:29 AM in reply to: EmyrGriffiths
This?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
0 Kudos
Post 3 of 6
01-06-2012 01:20 AM in reply to: Charles_Shade
That's exactly it! I would have put the grip on the very end though to make smnaps easier. Big question though... how did you do it?
0 Kudos
Post 4 of 6
01-06-2012 01:27 AM in reply to: EmyrGriffiths
Worked out what you've done and I wasn't far off.
The grip ios at the end but I would like to sue that to snap to a location but the window stretches further than the grips. How can I change this?
Distinguished Contributor
7 Kudos
Post 5 of 6
01-06-2012 01:44 AM in reply to: EmyrGriffiths
Thomas
0 Kudos
Post 6 of 6
01-06-2012 01:49 AM in reply to: Thomas.l
Thank you both. Massive help
Post to the Community
New Post
