Dynamic Blocks Forum
Dynamic block - stretching equally in same direction
5 REPLIES 5
EmyrGriffiths
3553 Views, 5 Replies
I can create a block where you stretch a line and the opposite side stretches equally in an opposite direction but I can't find anything to help with stetching equally in the same direction.
The block in questions is a door with windows to the side. The door size will remain fixed but as I stetch the window jamb I would like the two mullions to stretch to create an equal stretch.
I've had a look for a how-to but can't find anything similar. Can anyone help?
5 REPLIES 5
That's exactly it! I would have put the grip on the very end though to make smnaps easier. Big question though... how did you do it?
Worked out what you've done and I wasn't far off.
The grip ios at the end but I would like to sue that to snap to a location but the window stretches further than the grips. How can I change this?
Thomas.l
in reply to: EmyrGriffiths
You can change the scale of stretching.
This can be done in the proporty window of the action
(it is called distance multiplyer)
If you set this parameter to 1/3 it wil normaly work just fine
Thomas
EmyrGriffiths
in reply to: Thomas.l
Thank you both. Massive help
”Boost
”Tips
”Services
