I know I have been told several times that dynamic blocks are just for 2d but not so. Here is an example of a 3d dynamic tray. It is modeled after B-line aluminum H46 cable tray. I have set the lenght to 20ft as it is its maximum span. You can chose from 6" to 42" width trays. The rung spacing is set at 9". You will notice this dynamic block uses meshes and 3d solids to give us the tray we desired. Note you can only stretch in the X or Y direction. It would be awesome if Autodesk would allow us to stretch in the Z direction as well!
Enjoy....
@Anonymous I've made a 3D block too a little while ago. I had some help with the lookups. I think it's an accomplishment.
I think your block is quite an accomplishment! I really enjoyed the enginutity used in this block. I noticed you used a revolved surface in your block, because you are arraying it you could use a 3dSOLID, but that can lead to a larger block size.
I also enjoyed the use of the function inside the field to determone the length.
I did notice when I changed the rotation angle to 225 I did notice that part of the block went the wrong way.
Other than that I believe you have a grat Block on your hands!
What is this block of? corrugated pipe?
Thanks. I had a bit of help with the lookups at the beginning. I'm starting to see things a little more clearly than i used to, when it comes to lookups.
I noticed that object went the wrong way after the fact. I forgot about it.
The block is used to represent hvac flex duct for a minor detailed example. Using 3d solids made the block significantly larger than it needed to be.
Hi Folks,
Here's my contribution. I needed a Section Reference block with flexibility, so I crafted this one up. I still need to make a vertical version to compliment it, but here's how it works. you can flip the tail left or right, flip the direction arrow up or down, stretch the section cut lines, stretch the entire tail closer or farther, and if more references need to be indicated, you can flip half of the arrow and/or the "under curve" to make room for the multi-line text.
Any suggestions for improvement are always welcome. I hope you like it 🙂
Cynthia
After a quick chat with my boss, we decided to go a different route. Here's the same block but using visibility states 🙂
Here is a d.b. I remade from another user that I found very intriguing.
The dimensions on top references a circle's X-axes only, so no matter where you copy or move it, the distance from 0,0 is shown. (rounded to the nearest inch)
The bottom d.b. is the same concept but the 0,0 is referenced from the block itself instead of the drawings ucs location by having a nested block and arraying the dimension.
Here's a Scale bar for Metric and Imperial drawings. It has 19 Metric scales and 16 Imperial scales. As always, advice on improving the block is welcome 🙂
I did some refinements to the Scale Bar. I found some errors and changed some of the layout.
Here's a simple arrow block with a non rotating indicator 🙂
Hey guys,
Here's a file with multiple dynamic blocks.....I use these on a daily basis. I KNOW there's many ways to improve them.....and I KNOW you'll let me know!!
- Doors in plan and in section
- Windows in Section
- Items for paper space labelling
- Section Cuts and Detail Call-Out
- Wood Blocking, Wood Trim, Plywood
- Framing, Target and Roof Pitch Denotation
You guys are awesome. I have been living in the stone age not using dynamic blocks. Stumbled on this website after deciding that I had to start using them. Some great samples on here. Appreciative to everyone who has upload.
I like using an angular dimension for the arc of a door so I can manipulate the door swing angle with any angle. It can be used to remove a flip parameter.
