Dynamic Blocks
Dynamic Blocks
Distinguished Contributor
amflasf
Message 1 of 13 (300 Views)
Dynamic Block Help!
300 Views, 12 Replies
11-26-2012 04:52 PM
Can someone help me with this dynamic block...when I stretch it the arrows do weird things.
It would be nice to stretch with the arrows not losing their shape.
Any thoughts. I've attached the file if someone can assist on making it work right and forwarding it back.
That would be very much appreciated!
Thanks!
scot-65
Message 2 of 13 (284 Views)
Re: Dynamic Block Help!
11-27-2012 03:22 PM in reply to: amflasf
Try posting your inquiry here:
http://forums.autodesk.com/t5/Dynamic-Blocks/bd-p/154
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
Charles_Shade
Message 3 of 13 (275 Views)
11-27-2012 04:26 PM in reply to: amflasf
I do not believe that you will be able to get the Arrows to rotate with the change in the Radius of the Arc.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
amflasf
Message 4 of 13 (272 Views)
11-27-2012 05:57 PM in reply to: Charles_Shade
I don't understand why they can't stretch in place.
Maybe it is because of the angle of the arc?
Other suggestions on how I can achieve this same symbol look and get it to work?
Valued Mentor
AcadAdamLT
Message 5 of 13 (263 Views)
11-28-2012 02:24 AM in reply to: amflasf
The angle changes on the arc the more you stretch it, for the arrows to stay aligned it would require that they be rotated in accordance, this could be done with a move and rotation parameter combined with a Block property tablet and some mathematics.
Not something I can throw my mind into right now and I wouldn't be able to guarantee success either, your gonna have to prioritize, will this save you enough time to make up for the amount of time spent making this right?
Signature, sincerely... //Adam
AutoCad LT 2014
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Active Contributor
lxpichet
Message 6 of 13 (255 Views)
11-28-2012 04:40 AM in reply to: amflasf
Hi, please see attached file for a possible solution.
Since Autocad 2010, most of previous dynamic issues can be solved by combining parametrics with dynamic actions.
I changed a few little things in the bloc you posted and it is now functionnal, please see attached file. Note that there is a doted line on Deftpoints for guidance in the bloc: this line will not print.
Regards
Louis-Xavier Pichet
Charles_Shade
Message 7 of 13 (249 Views)
11-28-2012 04:51 AM in reply to: lxpichet
...unless you have access to a version of AutoCAD that allows Geometric Constraints to be used.
LT Versions do not have this functionality.
Active Contributor
lxpichet
Message 8 of 13 (246 Views)
11-28-2012 05:05 AM in reply to: Charles_Shade
Hi Charles,
I know this fact. However, the original post did not request any version nor did it specify an LT version.
Louis-Xavier Pichet
Charles_Shade
Message 9 of 13 (239 Views)
11-28-2012 05:44 AM in reply to: lxpichet
That was to let others who may come across this post know a limitation and to update my original response that this could not be achieved.
You showed the OP a way to do what he requested.
amflasf
Message 10 of 13 (230 Views)
11-28-2012 08:54 AM in reply to: amflasf
Thanks so much for shooting back a 'fixed' version of the dynamic block.
Unfortunately, we're working on CAD 2007 and I can't open it or convert it with TrueView.
Do you mind saving it down and reposting?
Much appreciated!
