Dynamic Blocks Forum
Dynamic Block Help
1 REPLY 1
247 Views, 1 Reply
Dynamic Block Help
I have attached my dynamic block for some additional help.
I have multiple visibility settings. If we're looking at the Detail one, I would llike to make the leader portion have a straight portion and then the ability to rotate it at that straight end. The way it is set up now I have to rotate first then stretch so the rotation point remains connected to the straight end.
How do I get this to work where I can stretch first and then rotate? You'll notice if I do it in this order the rotated portion moves away from the end of the straight edge.
Thanks for the help in advance.
1 REPLY 1
Charles_Shade
You need to move the Stretch to the Rotate point or include the Rotate Parameter in the Stretch Action where it is currently located (This is likely your solution).
As it is now when you Stretch the two ends the entity to the right is still being acted upon by the Rotate but is beyond the center point of the Rotate Action. (As is the entity to the left now past the point as well.)
”Boost
”Tips
”Services
