Dynamic Blocks Forum
Dynamic Block, Field "value" not updating Attribute "value"
9 REPLIES 9
Message 1 of 10
jhebert
6661 Views, 9 Replies
I have created a rectangle whose length changes.
The value of the paameter "Dist1" is this length field that I associate to the attribute value. Basically, echo length from Dist1 into the attrib value.
The problem is when I insert the block into the drawing the value is shown as "DIST1", even after regen.
Once I pull the grip point to a new length and regen it still shows "DIST1".
If I go into the ddedit and select the edit box (for multiline data field) the shown value will correct itself, but only one time.
If I change the length again, the dimension does not update.
It worked fine when I tested the block but is having issues days later.
Any suggestions?  thx .j.
9 REPLIES 9
Message 2 of 10
Bob_Zurunkle
in reply to: jhebert
Is FIELDEVAL set to 31?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 3 of 10
jhebert
No sir it was set to zero, let me check this now.
...And there it works now....Thank you very much, kind sir.
thx again for the help.  Would you know where I could find that information, I searched all morning for it on the web but was unable to ferret it out.  Thank you very much.  .j.
Message 4 of 10
rbh1
I found this in the AutoCad Command Reference
To update fields automatically
  1. At the Command prompt, enter fieldeval.
  2. Enter a bitcode that is the sum of any of the following values:
    • 0: Not updated
    • 1: Updated on open
    • 2:Updated on save
    • 4:Updated on plot
    • 8:Updated on use of ETRANSMIT
    • 16: Updated on regeneration
    For example, to update fields only when the file is opened, saved, or plotted, enter 7.
    Type:Integer
    Saved in:Drawing
    Initial value:31
    Controls how fields are updated.
    The setting is stored as a bitcode using the sum of the following values:
    0
    Not updated
    1
    Updated on open
    2
    Updated on save
    4
    Updated on plot
    8
    16
    NoteThe Date field is updated by UPDATEFIELD, but it is not updated automatically based on the setting of the FIELDEVAL system variable.
    I hope this helps
Message 5 of 10
Charles_Shade
in reply to: rbh1
The summing of the Codes listed in Help is also true of OSMODE and SORTENTS
Any others?
Message 6 of 10
tHIS IS NOT A SOLUTION
Message 7 of 10
timothy_crouse
Can you post the block?
-Tim C.
Message 8 of 10
jsmithAP3Q4
I believe I'm having the same problem, but the FIELDEVAL fix isn't working for me. Sample file attached.
Message 9 of 10
pendean
in reply to: jsmithAP3Q4
Thanks for sharing your file: please explain where/what each field's OBJECT is getting its data
Some of these appear to get info from somewhere, but where
Message 10 of 10
jsmithAP3Q4
in reply to: pendean
The column on the left contains the attribute definitions so the values may be updated after the block is inserted. The column on the right contains an mtext with a field entry that is linked to the value of the corresponding attribute definition (i.e. the field in the right column row 1 references the attribute definition for the left column row 1; rinse and repeat all the way up).
Some values that are being shown are the default values for some attributes, but if I change an attribute value after the block is inserted, no combination of fieldeval/regen/plot/etransmit gets the mtext field to update.
”Boost
”Tips
”Services
