I got autocad lt 2014, i turned on coordinates to my curser but when i snap onto a block my coords dissapear until i move my curser off of it. how can i fix it to stay?
What is the COORDS Variable set to?
What is the DYNPICOORDS Variable set to?
What is the DYNMODE (and other Dynaminc Input Variables) set to?
Perhaps DYNPIVIS set to 2
Need to narrow down your set-up.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
My dynpicoords are set to absoulute
dynmode is enabled and have it set to show 2 dimension
coords is abosulute, have pointer visiblitity set to always on.
my coords shows at my curser all the time until i snap onto a grip block, then they dissapear until i move it. it off then they come back.
Please relay the number selection of the Variable so I do not have to go and look those up.
DYNPICOORDS = 1
COORDS = 1
DYNPIVIS = 2
These settings will continue to show the Coords when you hover over a Grip. These will however dissappear when the Grip turns Hot. The system is expecting you to do something therefore it does not see the need for the Coordinates is what I am seeing. I do not know if you can increase the time that the Coords appear at the grip.
And the Dynamic Input tab of the Drafting Settings dialog does not seem to offer an option to see Coordintes during the use of a Grip to move an entity or otherwise manipulate it.
