Dynamic Blocks
Dynamic Blocks
Member
rickp
Message 1 of 9 (375 Views)
Dynamic block attributes not updating constants
375 Views, 8 Replies
02-27-2014 07:01 AM
I have read through all the forum posts regarding Dynamic block attributes not updating, but I have not seen an answer to my question.
I use attext in Autocad LT 2014 to extract data from attributes in the drawing.    The block has 7 attributes, and 3 of 7 are constants.    If I insert blocks in the drawing and run the attext command, the data extracts without an issue.     However, if I make a change to any blocks already inserted into the drawing, then all the constant attribute values disappear in the attext report.
The attached PDF expains the problem.    I have also included the block and attext template file.
Does anyone know why the constant attributes disappear after a block edit?
Valued Mentor
AcadAdamLT
Message 2 of 9 (370 Views)
Re: Dynamic block attributes not updating constants
02-27-2014 07:23 AM in reply to: rickp
Tried running "Attsync" after you've made changes to the block?
Signature, sincerely... //Adam
AutoCad LT 2014
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Member
rickp
Message 3 of 9 (362 Views)
02-27-2014 03:05 PM in reply to: AcadAdamLT
Yes I run attsyn after updating the block but it does not solve the problem
Valued Contributor
Imui
Message 4 of 9 (350 Views)
02-28-2014 03:49 AM in reply to: rickp
Hello
Could you post 2010 version dwg.
Member
rickp
Message 5 of 9 (345 Views)
02-28-2014 10:50 AM in reply to: rickp
Posting version 2010 as requested
Charles_Shade
Message 6 of 9 (331 Views)
02-28-2014 01:57 PM in reply to: rickp
After you change one and the ATTEXT no longer works run LIST and see if the Block is an anonymous name now and not the actual Block name.
SWAG.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
rickp
Message 7 of 9 (318 Views)
03-02-2014 08:40 PM in reply to: Charles_Shade
I ran list command before and after the block edit.    Before the edit, the block only had a block name.    After the edit it still had the proper block name, but it also had an anonymouse name.   What does this mean?
Charles_Shade
Message 8 of 9 (285 Views)
03-04-2014 07:49 AM in reply to: rickp
I am wondering if the anonymous name is what is crashing your extraction file and I don't know a solution right off for that.
Valued Contributor
Imui
Message 9 of 9 (264 Views)
03-05-2014 04:59 AM in reply to: Charles_Shade
make any change to the block and then reset it. now it will export correctly. Unfortunately takes out the "dynamic" from the dynamic block
