I am attempting to assign an align parameter to a dynamic block. My block is a 48" x 6" window, quite simple. I need it to be able to snap to a 45 degree line. I don't understand the steps I need to take to get this to work! I need step by step instructions on assigning the alignment parameter and making it so I can use the window in either the hirizontal or 45 degree aligned positions. The book is not easy to follow...(I jhave the "AutoCAD 2014 and Its Applications" text by Shumaker)
Thanks!
Kirsten
Solved by kkfrank. Go to Solution.
Hello all,
Nevermind...I finally figured it out. I am butchering myself with trying to make things harder than they actually are! I finally figure out I just need to pick the center of my window and the side along that horizontal line and that's all. I was putting in too many selections! Now to try some of the action parameters. Flip worked fine for me right away...
Ugh.
