heleads wrote:
> Does anyone have a work around for being able to create a post (in plan view) and array it into a grid where you can dynamically change the x and y spacing? Also say you have a grid of arrayed objects, can you turn the visibility off for a particular object that has been arrayed, while leaving the rest on?
The 1st part of your set of issues I have no familiarity with - yet.
Due mainly to not having 2K6 at this point
We are waiting until a certain Project is in to the Reviewing Agency,
prior to our deployment of 2K6 heleads.
But as regards the visibility issue, it's difficult for me to tell if
you mean that the objects in the Array are all "separate" DynBlocks, or
all part of one DynBlock?
An Array is distinct from a Group - Pieces (array) vs. Pieces of a Whole
(group).
And now that I'm in tune with Array, I'm thinking that your use of
"dynamically" in that reference is more happenstance, than due to the
DynBlock's capabilities.
Once you utilize Array, you just are left with more individual DynBlocks
- aren't you?
Maybe you should think through once more, and then maybe rephrase your
queries?
Don't give up the ship in your attempt to gain a more full understanding
of DynBlocks.
And I won't either heleads. 😉
HTH
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT/CD-2K4
AMD Athlon 64 X2 Dual 2.01GHz
XPPro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
