Dynamic Blocks
Dynamic Blocks
Valued Contributor
1 Kudo
Post 1 of 3
Door Swing Arc Does Not Scale Correctly
852 Views, 2 Replies
06-19-2012 10:24 AM
The attached is a plan view of a box with a door.
I am trying to get the door swing arc to scale correctly as the width of the box is changed.
But the block is defying logic by scaling the arc radius exactly 5 units short of what it should be.
I've tried deleting, recreating, and chaining the parameter over and over only to have the same problem each time.
Can anyone help?
Thanks!
Pete
The block seems OK to me.  I think you may have made some changes to the block definition, but did not "reset/update" the block that's in the drawing.  (Right-click > Reset)
*Pro
169 Kudos
Post 2 of 3
Re: Door Swing Arc Does Not Scale Correctly
06-19-2012 11:11 AM in reply to: pete592
Valued Contributor
1 Kudo
Post 3 of 3
06-19-2012 11:14 AM in reply to: pete592
Reset the block, what a concept!
Thanks!  I figured it was something easy.
