The attached is a plan view of a box with a door.
I am trying to get the door swing arc to scale correctly as the width of the box is changed.
But the block is defying logic by scaling the arc radius exactly 5 units short of what it should be.
I've tried deleting, recreating, and chaining the parameter over and over only to have the same problem each time.
Can anyone help?
Thanks!
Pete
Solved by nestly. Go to Solution.
The block seems OK to me. I think you may have made some changes to the block definition, but did not "reset/update" the block that's in the drawing. (Right-click > Reset)
You are using a stretch command on the arc instead of a scale. I think you should start your own thread if you need more assistance.
