Dynamic Blocks Forum
Door Swing Arc Does Not Scale Correctly
4 REPLIES 4
pete592
1943 Views, 4 Replies
The attached is a plan view of a box with a door.
I am trying to get the door swing arc to scale correctly as the width of the box is changed.
But the block is defying logic by scaling the arc radius exactly 5 units short of what it should be.
I've tried deleting, recreating, and chaining the parameter over and over only to have the same problem each time.
Can anyone help?
Thanks!
Pete
4 REPLIES 4
nestly
in reply to: pete592
The block seems OK to me.  I think you may have made some changes to the block definition, but did not "reset/update" the block that's in the drawing.  (Right-click > Reset)
pete592
Reset the block, what a concept!
Thanks!  I figured it was something easy.
jeffrose7
in reply to: nestly
I am having the same problem, but the "reset block" function does not work. Any suggestions?
Libbya
in reply to: jeffrose7
You are using a stretch command on the arc instead of a scale.  I think you should start your own thread if you need more assistance.
”Boost
”Tips
”Services
