My office are trying to create door blocks and they are listing out all the various options which is taking them an age! I've suggested the attached as an alternative but the only problem is the arc of the door swing doesn't change consistenlty with the door leaf and door opening.
Can anyone shed any light on this? Got to be something to do with distance and selecting the arc but I'm not sure!
Many thanks
Em
I would make it more like this.
For the changing of the arc i simply used a scale action.
And i added an alignment parameter to align it with the wall you want to atache it to.
regards
Thomas
Thanks Thomas. I've just seen someone elses door where they have used scale whcih I've also just tried. I still think stetch on the door leaf is the right way otherwise it narrows as well. Yours and my latest have the same issue - scaling the arc doesn't realte to a base point. I don't know if this is because of the origin of the arc in relation to the origin of the block
A few years back a number of us posted examples of our DynBlks in a post titled Dynamic Blocks Show-Off. I posted several versions of doors which can be dragged to a number of sizes, and opened any multiple of 15 degrees all the way from closed to 180 degrees, and which had a door arc that changed with the size and angle of swing. It had something to do with using an angle dimension with overrides. You should search for it or something similar....
The Scale does relate to a base point: The base of the Stretch Action.
Unless the Action used to drive the Scale and the Center of the Arc are at the same point you get the error that you see.
The distance (X & Y) of the center of the Arc is also being Scaled with the Scale Action thus moving the center point.
So's you don't have to look too hard, Bob's solution attached (in my own way).
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Getting a little closer to what I want. Would rather the base point else where but unfortunately there is the scaling issue with the arc
If it helps with implementing the Block you can move just the Grip of the Distance2 Parameter to a more suitable location.
This will not affect the function of the Parameter or its assigned Actions.
I must add that the angled dimension wasn't my idea, but that's part of what these forums are all about 🙂
Charles - I've just realised that my block won't work properly when it's flipped then stretched, Pretty much tried doing what you have done. From what I can see settings are the same apart from door leaf angle. Not sure what I've done wrong. Any hints?
Try not including Actions in the Flip.
Though this is not alwyas the case.
Always post what you got if there is a problem.
If it's like the one I posted, I never could get flip actions to work nicely with that polar rotate and stretch either.
