I have made a typical mechanical square to round symbol that allows the user to stretch the edges to fit whatever length they need. When stretching the reference dimension (autocad feature not something I put in) shows up so you know how long the total length of the line is. If I try to input the total length rather then just stretch it, the end result is incorrect. If I trying shrinking the object through the stretch action and input the length the results are even worse. I don't unerstand why this happens with this block and not others. Attached is the block I am refering to. Can anyone tell me what the problem is?
