I've created a dynamic block which several versions, each version has its properties managed by a table bloc.:
When I insert the bloc for the 1st time, all user properties are set to "1" :
I need to select a version in the list to have the right properties in the palette :
Is there a way to define a default lilne, which is used to set default properties on insertion ?
Solved by Libbya. Go to Solution.
The 'default' can be entered when you create the user property under 'Value'. The defulat for 'value' is 1 unit. Change it on creation of the user property to whatever you want. I do not know how to enter a different default after the user property has been created.
Effectively, when I create a parameter, the Value is the "Default value", which is independant from the current value. Oncve created, it can be modified in the Parameter table, in Expression :
