I have a dynamic column bubble block with a couple visiblity states. Not sure if I'm going about this the correct or most logical way but here goes....
what I would like to have is an attribute that defaults to the value of another attribute.
in other words when you insert the block it asks you for a column number. its inserted with a standard large text size. if the text is to big then you can switch it to another visiblity state using a smaller text size. This smalled text is also an attribute & uses the value of the larger text for it's value. I've been trying to do it by using a field but can't seem to get it to work.
Hopefully this makes sense. Any help would be appreciated
Chuck
