I have block that I have started working on. It is basically a pipe manifold with pipes coming out of the sides. As I stretch the manifold, I want it to add pipes every 12". This part works, but the problem is that it doesn't add the next pipe until I am about 10" past where the pipe belongs. I would like this to happen when I am about 2" past where the next pipe would go.
I have the end of my manifold currently 2" past the first pipe. I added my array command at this point, hoping that would mean that when I stretch the manifold 12" it would add one pipe. Not happening though.
Attached is the file I'm working on. I'd love some input.
Solved by ojuris. Go to Solution.
