Dynamic Blocks Forum
Custom grips Disappear
3 REPLIES 3
Holly_Jones
662 Views, 3 Replies
Yesterday I inserted 2 different dynblocks in a drawing, this morning the custom grips were gone. It seems like the dynblocks are locked. I reinserted the dynblocks and the ones I reinserted work as expected but the ones from yesterday do not work at all.
See attached drawing, the blocks I inserted this morning are on layer 0.
LT2009 (I know Smiley Embarassed)- so I can't use any new fangled commands.
Thanks for any input
3 REPLIES 3
steven-g
in reply to: Holly_Jones
The first block has had it's Z scale set to 0 (check in the properties), it should be the same value as the X & Y scales. As a note you can scale a dynamic block but all 3 axis have to be the same for dynamic properties to work, so even changing the Z scale which usually has no bearing on an object will still stop the dynamic properties working.
Holly_Jones
in reply to: steven-g
Thank-you Steven. Not sure why the Z scale would have changed to 0. I must have done something...
Holly
frfabi
To avoid this problem:
1) Select the block
1) BEDIT
2) _PROPERTY
3) set "Scale Uniformly" to "YES"
All done  Smiley Happy
”Boost
”Tips
”Services
