Dynamic Blocks Forum
Constraints in DB with text, Help
2 REPLIES 2
jarredmonday
415 Views, 2 Replies
In the attached file I am attempting to keep the dimension text in the center of the diagonal line. When the constraint is applied the line and the text midpoint reverts back to its original coordinates. Are there any other methods to keeping the text in the middle of the rectangle? (Refresh when done)
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
2 REPLIES 2
Libbya
in reply to: jarredmonday
Remove the constraints and add another stretch to distance4 and distance3 (if I understand your block correctly...) to move the Size attribute.  Set the distance multiplier of the stretch to 0.5.  See attached.
jarredmonday
in reply to: Libbya
smh...duh! Well thanks. I don't know why I didn't think of that the first place Smiley Indifferent
”Boost
”Tips
”Services
