Dynamic Blocks
Dynamic Blocks
Member
Remlapw
Message 1 of 2 (167 Views)
Conditional Visibility Help
167 Views, 1 Replies
09-06-2012 04:52 PM
Hi I am currently creating many dynamic blocks and I have the need for visibility states.  What I would like appear invisible in one of the two states is a polygon surrounding a text attribute.  I would like this polygon to become invisible when the text attribute inside of it has no value filled in and visible when there is a value to the attribute.  Is this possible?
I am using Autocad Electrical 2011
Will
Distinguished Mentor
Moshe-A
Message 2 of 2 (132 Views)
Re: Conditional Visibility Help
09-23-2012 01:35 PM in reply to: Remlapw
can you post a sample block here? describe how it's function?
when an attribute value is nothing (null string value) do you
know how to select it the next time you want to set it?
as far as i know there is no build-in solution to this but with VisualLisp
it can be solved.
cheers
moshe
