I'm having some issues with dynamic blocks, what i have 4 bits of texts (stamps) which are all blocks, what i want to do is be able to insert one dynamic block with a look up and just choose 1 of the 4 to use on that paticular drawing. im having trouble at the moment, working out how to do it.
PLEASE HELP!
Solved by Libbya. Go to Solution.
Insert all four blocks into a drawing.
Create a block which houses the four blocks.
Insert a visibility parameter.
Define 4 visibility states - one for each block.
Hide the three unwanted blocks in each of the states.
Save block.
