Dynamic Blocks Forum
Change text & attribute value
1 REPLY 1
edburkett
201 Views, 1 Reply
I have just started playing with dynamic blocks. I have a block that represents a part that is available in a number of standard lengths. Each length has a different part number. I have been able to use a linear parameter with a list of specific values to control a stretch action so that one block can be used for all lengths. Now I need to add a text (or attribute) label that gives the length of the part and an attribute that contains the appropriate part number. It seems like this should be done with a lookup table but I just cant figure out how to do it. I've read some posts that say an attribute value can be a field that can be pointed to a lookup table.
Anyone able to help me out?
1 REPLY 1
in reply to: edburkett
You can add an attribute with two BlockPlaceholder fields that pointed to the Linear parameter (for length) and the Lookup parameter (for part number).
”Boost
”Tips
”Services
